f22b1 swap poa ecu
    f22b1 swap poa ecu
    well i have been lookin around on here for a while and havent found much out about my prob
    ok did the swap and ecu repinned the ecu as said to and still nothing after 4k ?? so i do have a cel but cant figure out how to add a check piont to the ecu since my stock harness had none due to the led on the ecu
    so i guess my question is what ecu pins on a poa is for the check connector for the jumper to test the cel???
    oh yeah i ramble when i talk too with no punctuation
    Try not rambling with no punctuation here. You're asking us to take our time to help you... show us enough respect by typing in a manner that is able to be understood.
    The wiring should be there. Even though the 90 had the LED, the service connector should be present as well.
      OBD1 P0A MIL (CEL) pin is A13, same as the stock ECU.
      MR Thread
      GhostAccord 2.4L Blog
      by Chappy, on Flickr
        Thanks you guys. I did quite well in school, but i like James Joyce and ee cummings lol.
        :focus:
        Ok, So, as far as the connector, I looked on the pass side where it should be. It was nowhere to be found.
        Thanks the wire color and pin location should be of great assistance.
        Again sorry if i seemed disrespectful.
          We just get a lot of ignorant kids on here that type gibberish, and then follow with "sry i kno i suk at spellin lol"
          If you have enough time to comment on the fact that your typing is hard to understand, you have enough time to go back and re-read it to make sure it can be understood. Otherwise, those that know things will ignore you, and those that help might give you bad information, because they don't understand what you're asking!
          Anyway, I asked a friend of mine that had a 90, though he said it was a "later model"... basically, it wasn't one of the first models to roll off the line for the 1990 production year. I don't think it's likely, but it's POSSIBLE that there was a mid-year change. His car did indeed have the connector, though. It should be blue, though I've heard reports (never seen proof) of brown. Mine was wrapped in electrical tape, and hidden well.
          Unfortunately, my car is a 92, with a hack-job shop-installed H22, and a modified P28 ECU... so I'm not sure if I'd be able to help with my car as a reference.
            did you remove side panel cover on the passenger floor wall (right side), my CEL connector thing sits behind it. my connector is blue (2 female pin connector)
              You know Alko, i dont think i have looked behind there. Thanks.
              Deevergote, how do you like the p28? I am thinking about getting one but am unsure about getting the correct chip for my engine. The problem I'm having is i bought a 200 dollar car and installed a rebuild engine(i traded a stripped down 88 rx-7 for.) Most of the electrical connectors under the dizzy are brittle or broken. So i need to figure out what codes are thrown so i can fix the connectors
                The P28 is chipped... so basically it's just a blank canvas.
                You have the wrong idea about getting a chip, though. You don't "find the right chip". You have to have it tuned for your specific engine, or you run the risk of serious damage.
                You don't need a P28, as it's really only needed when you have a VTEC engine. You can use a P06.
                  deev, he's running an F22B1, which is the single cam VTEC engine.
                  OP, I have a very good base map for the F22B1 if you ever deside to go with a P28. It will get you started and to the tuner of your choice.
                    Oh yeah, sorry... I got confused with another thread where the guy was asking about an F22A.
                    In that case, yes, the P28 is the ECU to use.
