So the other day when I went to start my car...well, it didn't. Then I held the ignition while pressing the gas for about 15 seconds and then it turned on. Later that night I was driving it and WAM! the engine turns off while I was driving it I really have no idea what is wrong with it because it keeps happening. I dont know if this helps but it started happening after I got an oil change...I checked the oil and there seemed to be no problem.
My car sometimes won't start, but other times it will.
http://www.cb7tuner.com/vbb/showthread.php?t=53888&
I would start at the main relay. ^^^Here is a DIY on how to fix them
Originally posted by plee3 View Posthttp://www.cb7tuner.com/vbb/showthread.php?t=53888&
I would start at the main relay. ^^^Here is a DIY on how to fix themSig removed due to excessive size.
The main relay COULD cause it to cut out, but I don't know of that ever happening.
The first thing to check would be the battery connections and grounds. Make sure all are clean and tight. It's free and easy to check those things.
Next, check to see if the problem is spark or fuel. The next time it doesn't start, listen for the fuel pump. If that comes on, the main relay is not the culprit. If you can't hear the pump, get out and pull a spark plug. Disconnect the distributor, so the car isn't getting any spark (you don't want it to start with a plug out!) and crank it. Smell for fuel. If you smell fuel, then you can most likely rule out a fueling issue.
Now you look to spark. Keep that plug out. Reconnect the distributor, and crank the engine briefly, checkng for spark. It's best to hold the plug near something that the spark will arc to, so you can see it.
No spark, then you're going to want to replace your ignition coil and/or igniter.
No-start problems are common wheb it gets hot out.
Originally posted by deevergote View PostThe main relay COULD cause it to cut out, but I don't know of that ever happening.
Originally posted by osl View PostThe main relay wouldn't make your car die though. You just wouldn't be able to start it.
but it sounds like it may be the problem for the OP.Originally posted by scudweiseronce again people, need i remind you that there is no road between the kitchen and the bedroom, and therefore women need not drive?
Originally posted by pedalpusher90 View PostJust out of curiosity what is the ignitor?
Similar to an ignitor on a bbq.
Originally posted by Zeusimo View PostGood Job Man
just fyi.
