Hello, I have a problem with my accord, runs and drives fine exept for my antifreeze..ill be driving normally...60 65mph my temp gauge will skyrocket I have to turn my heat on full blast and switch my radiator fan on pretty much as soon as I start driving.. its a newer radiator..I wired up a slim fan the lower hose stays nice and cool the upper hose is very very hot..even with the fan blowing on it...ill shut it off and you can hear it boiling and see it boiling in the coolant resivour... any ideas??? I'm tired of driving around in 85degree weather with the heat cranked...
91 Accord anti-freeze boiling?
thermostat dead on. ONLY GO WITH AN OEM THERMOSTAT!!!! I always had them aftermarket ones fail after a year or so, oem is only a little more but they last a LONG time!
Replace that, maybe the hose if you didnt already and put a new radiator cap.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztech View Postthermostat dead on. ONLY GO WITH AN OEM THERMOSTAT!!!! I always had them aftermarket ones fail after a year or so, oem is only a little more but they last a LONG time!
Replace that, maybe the hose if you didnt already and put a new radiator cap.Sig removed due to excessive size.
Originally posted by slowaccord View PostBought a new radiator cap from advanced auto, the spring and everything inside the cap broke off a week after having it on there...I lost the recipt or id bring it back...ill pick up a new thermostat soon, should I just take the thermostat out till I get a new one?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
man should of went oem, I think its a few bucks more.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
