High flow ai vs "normal" ai
    So, what's the difference between high flow air intake and the "normal" air intake? And does those have any kind of difference if i don't make any kind of air "ramming" to the filter? Basicly i would just put a intake and a filter.
    pictures below...don't know if my terms are correct.
    http://cgi.ebay.com/ebaymotors/HIGH-...Q5fAccessories
    http://cgi.ebay.com/ebaymotors/98-02...Q5fAccessories
    And i don't mean the difference between the specific items but generally.
    What's the difference in the shape of the high performance filters?
    I think your asking the difference between a cold air intake and a short ram intake?
    If so there really is no difference. Cold air intakes tend to be located lower in the engine bay so they only pull in cold air as opposed to short air intakes which are located usually near the battery and would pull in hot air from the engine.
    Even though both would increase performance, the CAI will only slightly improve over the SRI.
    Nothing you would notice anyway.
    And the CAI will hydrolock your motor if you go through big puddles in a rain storm.
      Oh and the links posted are only a sri and a 3'' filter.
      Filter size doesn't really matter all that much.
        Thanks for the reply. But no I didn't mean CAI vs SRI. But if you look closely the other filter has got the top end open and the other one hasn't. So basicly that is what i'm asking. What's the difference with those. And also what's the difference between filter shapes.
        http://www.knfilters.com/universal/universal.htm
          CAI affects the upper RPMs more, SRI; the lower RPMs, really not a noticeable difference to the butt dyno though.
          A CAI only hydrolocks your motor if you don't have a bypass in it. If you're running a CAI on the street without a bypass in it, you take your chances. But you do have to have the entire filter almost completely submerged in order to suck water into the intake tube. If air can flow into the filter, it'll pull that in before it picks up the water.
