Does anybody know how to do the G22 vtec swap. F22 block and H22 head ???
G22vtec
I have a friend that has that swap and he has had the same motor boosted and lasted for 2 yrs. It depends on the internals with a well built and tuned motor. I plan on trying that swap also when my current motor decides to die on me. Till then, there are different forums that gives exact detail about the swap, and IMPORT Tuner magazine had full instructions on that build last yr. Happy searching...
1) The G series is a 5 cylinder engine used in the Vigor. It is not a mix of the H and F series. This stupid "G series" name needs to die.
2) Such a swap will result in an engine that has low compression and a low redline... the head works best with high compression and a high redline. People say it's good for turbo... but the F22's pistons have very weak ringlands. They will blow. The F22's cylinder walls are made of iron, as opposed to the h22's FRM cylinder walls. The idea that FRM is a bad material is absolutely idiotic. It is more durable than the iron sleeves, and has better cooling properties. The ONLY benefit to iron sleeves is that you have a greater selection of pistons... but doing a cheap-ass budget swap like this RARELY involves proper forged pistons.
3) The bore size of the cylinders and the combustion chambers are different. Therefore, you will have overlap. Overlap creates sharp edges, which creates hot spots. Hot spots lead to detonation.
In other words, your "G22" swap is absolutely worthless. If you want an H22, get an H22. If you want performance from your F22 block, do some work to the F22 head... when properly modified, the F22 head is actually a better design than the H22 head.
Thank you. I also hate this, but I never say anything because then you have everyone else saying "ya it is called that, ur dumb".Originally posted by deevergote View Post1) The G series is a 5 cylinder engine used in the Vigor. It is not a mix of the H and F series. This stupid "G series" name needs to die.
You know, it might not be AS much of an annoyance (though an annoyance it still would be) if there were not a HONDA G series engine already out there.Originally posted by deevergote View Post1) The G series is a 5 cylinder engine used in the Vigor. It is not a mix of the H and F series. This stupid "G series" name needs to die.__
__
Wouldn't it be better idea to stick a p&p f22a head with a bisi stage 2 cam on an h22 block?Last edited by cloudasc; 07-24-2010, 12:28 PM.
i still believe that would take too much fab work to get it correct. as it is with the h22 head on the f22 block, there are problems with the ports and the cylinder head would create the overlap.
Ive heard more of guys swapping f22ax heads on f23 blocks from the 6th gens. im not sure how the boring is on those but it might work better.
f23 - f22ax hybrid would be cool. throw some k20 pistons in there with, i think, an h23 crank? do the head work and get the correct timing belt, water pump, etc. would be pretty mean. i think they threw an h series head on one before. bore might be more similar in that case.
I learned something today. I always wondered what the Vigor I-5 was called... Now I know and knowing is half the battle *G.I.JOE*Originally posted by deevergote View Post1) The G series is a 5 cylinder engine used in the Vigor. It is not a mix of the H and F series. This stupid "G series" name needs to die.Call me Travis.
2006 Cobalt LS/SC ~ "Burt the Bloody Bumble Bee"
1992 Accord LX ~ "Smoothie"
1991 CRX Si ~ Hellion
1989 GMC S15 ~ Oldie
