header o2 sensor
    header o2 sensor
    ok i bought header from ebay heres wat it looks like Honda Accord 90 91 92 93 Exhaust Header and CAT Combo but there is no 02 sensor hole is that a bad thing or good thing???
    can any one help?
      Link?
      Call me Travis.
      2006 Cobalt LS/SC ~ "Burt the Bloody Bumble Bee"
      1992 Accord LX ~ "Smoothie"
      1991 CRX Si ~ Hellion
      1989 GMC S15 ~ Oldie
        http://cgi.ebay.com/ebaymotors/ws/eB...OU%3AUS%3A1123
          i put the link up ^^^^^^^^^
            there is a o2 hole for a sensor on your header. If your running F22 than thats where the o2 sensor goes. If its h22, then you should have bought a h22 header with a downpipe and o2 hole in it.
              ok for the header i bought it says in the description no o2 sensor if lets say there isnt is it bad to not have it in????
                That header shows a 02 sensor bung on the #2 runner. As long as you have the F22 that should bolt up as your typical generic header.
                Now that I read it, the test pipe(catilytic converter replacement section of pipe) has no 02 bung so as long as you dont have emissions laws in your area for your year cb then you are fine, just cut the wires out and roll with it.
                Call me Travis.
                  you must have an o2 sensor in it, otherwise your car power, gas mileage etc will go crazy. And i can see a hole in a picture. Cobalt's right. 2nd "pipe" from the left has a slot for o2 sensor. I dont understand why they said it doesnt.
                    ight no problem thank you guys i was searching alot and couldnt find anything on it this was my second option but thanks now some 1 knows in the future
                      Keep in mind that the F22A6 (at least mine) has the O2 sensor on the flex pipe ahead of the converter, not on the manifold like the F22A1 in my LX's. If you have an LX, you should have the header with the port.
                        yea i have 93 accord lx
                          I edited my post, in the CB and all cars since the early 90's/late 80's they have 2-4 02 sensors. the CB and all other 4 cylinders(eccept maybe subies, I cant remember the last time I worked on one) have two, an upstream which affects your AFR and a down stream that checks your cat's efficiency. With the Test Pipe on there it is also removing the second 02 sensor since you no longer need it and it is just more production cost to drill a hole and weld a bung.
                          Call me Travis.
                            so wat does that mean brake it down???
                              that i dont need it???
