I can't find this crap, everyone says its right under the thermostat but I dont see it there. PLEASE HELP! Pics would be nice... but I need to do this before I run out of sunlight!
I Cannot Find Vss Please Help
Before digging for it, make sure it is the problem. If the VSS is bad, odometer, speedometer, and cruise control ALL will not work. If you have a manual, it should have some electrical checks to make sure its the VSS, not a bad connection/wire somewhere.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Woah, I've been out working on trying to get the bolt on the VSS on the passengers side out, but it's a pain in the ass. the extension i have does not fit, I just need my own tools.Originally posted by fleetw00d View PostBefore digging for it, make sure it is the problem. If the VSS is bad, odometer, speedometer, and cruise control ALL will not work. If you have a manual, it should have some electrical checks to make sure its the VSS, not a bad connection/wire somewhere.
Anyway, what are these electrical checks I can do?
Before you replace the VSS a few checks you can do is:
1) Observe if the spedometer is malfunctioning (sometimes reading correct speed sometimes not or on zero)
2) Try operating the cruise control and see if it will hold the speed you set consistently
3) Check the wiring loom to the VSS is not loose, corroded or damaged.
4) Check if your mileage counter is working consistently.Rides:
Accord
92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
96-AUDM-2.2 VTiS- Heather Mist
CR-X
88-JDM-Si- Black
CR-X Del Sol
92-JDM-SiR "Transtop" Motegi Edition - Silver
95-JDM-SiR "Transtop" Daytona Edition - Silver
92-JDM-SiR "Transtop" - Black
Prelude
91-JDM-Si-4ws "Si States" - Phoenix Red
91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
Good thinking. So many people replace components without cleaning the connections first, and end up wasting money. I blew $300 that way myself to learn that lesson!
Also, if anything is difficult to do... you probably don't have the proper tools. Step back, think, and ask questions if you need to... but always use the proper tools. You'll make the job much easier, and you'll greatly reduce the risk of damage or injury. That's another lesson I learned the hard way!
Yeah that's something I came to that conclusion last night, I just don't have the right tools right now. In fact, I don't own any tools, I'm borrowing a friend's generic tool box and the problem is that the socket extension is too wide.Originally posted by deevergote View PostGood thinking. So many people replace components without cleaning the connections first, and end up wasting money. I blew $300 that way myself to learn that lesson!
I just got paid this morning so I'm going to buy some tools today. I can't move from this point without them.
Make sure when you take the sensor apart you don't loose the piece that the gear spins between the top and bottom. Made that mistake before.
As Mike said make sure it is bad before you change it. I once swapped fuel pumps only to find out the main relay was bad. But ya live and learn.Bought From: Slammed4thGenOriginally posted by chessboxerWe know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
TypeG x2
Deevergote
BillKisme
Yeah, I have a small about on money to throw around with this, so I'm definitely checking to make sure it's the problem first. Blindly replacing parts is no the way to go here.. And yeah, will make sure not to lose the part, I don't think I'll have a problem with that, but it's not like it's going to fall INTO the trans, will it?Originally posted by PointBlank View PostMake sure when you take the sensor apart you don't loose the piece that the gear spins between the top and bottom. Made that mistake before.
It won't fall INTO the trans, but you already know how difficult it is to get to the VSS, just imaging trying to find that little drive rod if you drop it. If you're lucky, it would fall all the way through to the ground.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
