power steering problem
    why does my power steering reservoir start bubbling wen i turn on the car on...wen i drive the car it starts spilling out?
    Only thing I can think of is that it is managing to pull air into the pump and this shows up as bubbles in the reservoir. Can you tell which return line the bubbles are coming from? Are the connections at both ends of the inlet pipe tight? Is the inlet hose (from bottom of reservoir to pump) in good condition? Might even be a seal leak on the low pressure side of the pump allowing air in and since the pump is the highest point in the system, this point doesn't show up as a fluid leak when the engine is shut off.
      I have a thread a few days older than this one asking the same question. Seems to only happen in cold weather, right? Doesn't do it all the time in cold weather, right? Never seen it do it in warm weather? I can't believe there isn't a TSB or anything about this in All Data or Mitchel. Seems to be a problem that happens frequently.
      God created turbo lag to give eight cylinders a chance.
