I have a 1993 Honda Accord EX. The engine code on the side says f22a6. It is a DOHC engine. I was just wondering if it was a VTEC engine or not? I search online and seem to find no exact answers...and I can't trust wikipedia lol
Wondering if my engine is VTEC or non-vtec?
This topic is closed.
it should be a stock sohc engine unless you bought the car with a swap. if its have vtec it should say vtec on top of the valve cover. if the the bottom block have a code saying f22a6 then you have the stock sohc non vtec engine. or take a picture of your engine and it'll be easier to tell you what engine you have.
Originally posted by deevergote View PostUnless he bought a car with a headswap... then the block would say F22A6 and it could have a DOHC head on it.
Felony, post a picture of your engine.
The F22B DOHC head is an easy swap, and has been done quite a few times. He's in CA... lots of stuff going on over there. Either we assume he can't identify a DOHC engine, or we assume a headswap was done. Either way, we're making assumptions that may or may not be true. If he sees a DOHC head on an F22A6 block, I could see where confusion would occur.
In all honest, MOST of the information on Wikipedia regarding the CB and it's various engines is correct. The only information that isn't correct that I'm aware of is the compression ratio of various non-US model F series engines.
Originally posted by '93CB7Ex View PostI have TOHC.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Originally posted by GeoffMisiak View PostOk, what's TOHC?
Unless you have a Frankenstein head swap, it's probably just the stock 16 valve single cam. But, don't feel bad for asking...When I bought my Accord back in 2000 I basically asked the same questions to a friend of mine. We all have to start somewhere, and you only learn by asking.Last edited by wherm; 01-04-2011, 11:43 PM.
