how do i know if my engine is the f22 or the h22?
engine
There is a code on the front of the block left of the torque mount and next to the "peep hole" into the bell housing for timing. Or just search google images for f22 and h22. f22 is sohc, h22 is dohc and will say "vtec" on the valve cover.
You're going to get much better responses on this board if you actually try to do a bit of research before posting.My Member's Ride Thread
Are you positive? I thought it was the opposite...Originally posted by mikecb7LX92 View Postthe f22 have iron walls, as the h22 have FRM cylinder walls.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
This is correct.Originally posted by mikecb7LX92 View Postthe f22 have iron walls, as the h22 have FRM cylinder walls.
FRM is stronger, lighter, and better at conducting heat. However, it is not compatible with most forged pistons, which is why many people wrongfully believe that it is inferior to the F22A's iron sleeves.
Stock iron sleeves in a 20 year old economy engine are NOT designed to hold boost pressure (assuming that is what "pressure" means.) Neither are the internals... of ANY N/A Honda engine.
