I just got my h22a swap running but there is one issue, VTEC is engaging but it is redlining at 6000rpms. Does anyone have any idea what could cause this?
why is my H22A redlining at 6000rpms?
P13 and its a 5 speed. I have a ac autotechnic vtec controller and I think it may have something to do with it because in my old h22 cb7 the h would rev out at 6k before it was running temp and not hit vtec but now with the vtec controller it will hit vtec even on first start up in the mornings when its still cold. do you think that is some how causing it?
VTEC controller is a pretty big no-no. No reason to do that really. the car with crossover when its safe to do so. forcing VTEC while cold could do some damage, as well as trying to do it with too low oil pressure.
imagine having cylinders 1 and 2 running VTEC and 3 and 4 not... maybe inprobable but still.
H's wont run VTEC while cold or with a CEL code that relates to important sensors. Goes into limp mode, dumps fuel to prevent possible damage to the cylinders and drops redline for the same reason.
the ECU might even be seeing an issue because of the controller and is compensating for it.
I know it isn't supposed to kick in when cold and I just rebuilt the engine, timed it and put it in the car myself so I know the timing fine. there was what I thought to be a throttle body heater right on the bottom of the throttle body and one of the fittings broke off it so I bypassed it, I really don't know what the component is, could this have anything to do with it?
