Low Compression, Headgasket?
    So I just started working on a 1992 accord I bought 3 years ago. The car has 120psi on two cylinders and 60 on the other two. It has spark but Ive yet to check fuel. It wont start unless you use starting fluid then it just runs off that and dies. Is it common to get that kind of compression numbers with a blown head gasket? Could that be why it prevents it from running? Also whats a good place to get a used f22? I dont have junkyards around me with any honda parts. Thanks in advance.
    Didn't you ask this question last night?
    The answers still the same. About 180 is ideal.
    MRT
    sneaky motherfucker
      Yea but for some reason that thread got deleted! IDK what happened. Could that be the head gasket?
        im running about 145-150 as far as compression goes, but idk if the head gasket would cause a loss of compression
          It was deleted because you don't read.
          3 posts above your post - http://www.cb7tuner.com/vbb/showthread.php?t=168356 - It's even a sticky . . .
          I'll edit your thread title now, next time it will be deleted.
          My 5.7 LS1 Holden Ute
