F22a6 intake manifold
    I've seen it in the Jk, it looks like it can come apart. Ie, a section the holds the injectors, then it splits for the extra tube section. Does it actually come apart, or was it just made that way?
    MRT
    sneaky motherfucker
    there's 3 pieces. runners (part with injectors) iab plate, plenum. If you're still confused I have one apart I can take a pic of.
    Life's a garden. Dig it.
      //////////////Plenum
      ///////////Iabs
      ////Runners
      Like that? ^^^
      If you could, that'd be great.
      MRT
      sneaky motherfucker
        I could have had me an h23 intake manifold if I could have figured out how to remove it, actually I still don't know how to.
          I could've had an H23 manifold as well, until I realized it won't fit on an F!
          MRT
          sneaky motherfucker
            The H23 manifold will fit on an F22. The H22 manifold will not.
            Plenum up top, where the throttle body attaches to.
            IAB plate in the middle (this one is running spacers, which make easy-to-see separations between the parts.)
            Runners at the bottom.
              thank you sir. I was going to get around to taking a picture this morning.
                it has bolts and nuts that hold together and you can clearly see that but you still have to come on the forum and ask????????????
                you can even view this in a parts exploded diagram. if you werent in beginners forum, i would have blasted your ass already.
                  At least answering the question provides the answer for the next guy who wants to ask.
                    I guess the part I was asking about doesn't come apart. The bar right about where the studs are for the fuel rail. It looked like ti could come apart.
                    Are you 100% positive on the H22 H23? I know the H23 plenum will fit, I thought you had to use H22 or A6 runners...
                    I would gladly respond point by point, until you got so frustrated that you left!
                    But the diagram was a good thing. I went and looked and saw that it didn't come apart.
                    MRT
                    sneaky motherfucker
                      H23 runners will bolt up to the F22A head. The H22 runners will not. The plenum and IAB plates are the same on the two.
                        Ah. Well I guess I was just wrong.
                        MRT
                        sneaky motherfucker
                          Big suprise there.
                            Originally posted by Ralphie View Post
                            Big suprise there.
                            rofl
                              There's also the wicked sweet DIY spacer write up. You could do that.
                              But no, the H22 runners won't fit. Only corresponding specific parts Fx or H23.
                              life is good.
