I don't even know where to begin to try diagnosing the problem. It's certainly got gas, and the battery is fine because whenever I turn the key it chirps, but the engine just won't turn over. Any other obvious things I'm missing to check? Or perhaps the problem is bigger than I think..
Car just WILL NOT start
Any CELs?
You've got to give us at least something to work with...MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
True..well, no CEL's. When I stick the key in and try to start it, all it does is repeatedly chirp until I bring the key back to the on position. It makes it seem like the engine isn't even responding or attempting to start. I've tried doing a running start and that didn't prove either. I've tried jumping and neither did that..lol
Chirping is the chimes you hear when the key is in?MRT
Type of car?
Mostly looking for Auto or manual, but be specific so others can help.MRT
Is the engine getting fuel?
Is the engine getting spark?
Is the engine getting air?
It needs all of those 3 things to run. It will run if it has them, and it will not if one is missing. Determine which is missing, and it will make it MUCH easier to figure out what is wrong.
In the meantime, clean and tighten all battery and ground connections.
Edit:
There it is. http://www.cb7tuner.com/vbb/showpost...05&postcount=1
Originally posted by Ale_Malo View PostI'm pretty sure it's getting spark, and certain it's getting fuel. But air may be the issue. Is there any possible way to make sure that each of these, individually, are working?
The other ones, I'm not 100% on my methods.MRT
Spark and fuel are more likely. If you're sure it's getting spark, the spark may not be strong enough (a weak battery connection, be it loose or dirty, could be enough to turn the engine, but not start it... I've had that happen personally.) Are you POSITIVE it has fuel?
It's highly unlikely that the engine isn't getting air, unless the throttle plate somehow isn't opening.
