hidden battery?
    hidden battery?
    i have been thinking about this for a few weeks now .
    about hiding my battery under the front bumber cover.
    if any has done this mabee post some pic.s
    if not.
    what things sould i look out for?
    R.I.P 93 cb7
    Why does everyone always say "bumber"?
    A full size battery isn't going to fit there very well. Get one of those small Odyssey batteries and you can hide it pretty much anywhere you want. The best way would to be fabricate a bracket for it... though I've seen people just zip-tie them in place.
      yaaaaa zip ties just just will not work for me!
      R.I.P 93 cb7
        Then you'll want to look into doing something like this:
        That's in a Lotus, interior mount... but you can do something similar in the engine bay, trunk, whatever.
          is that in the trunk?
          i want mine were you will not be able to see it.
          i think it sticks out in a trunk ,
          just dont look right
          i feal if you are going to relocate your battery why not wide it wile your doing it.
          "my 2 cents"
          R.I.P 93 cb7
            mabee you can give me some info on that battery?
            were i can get it ?
            auto zone?
            advanced?
            etc.etc.etc.
            R.I.P 93 cb7
              That's just as an illustration. Simply showing you a battery relocation using an Odyssey battery and a custom bracket. If I was showing you EXACTLY what you should do, I'd have chosen a picture of a CB, not a Lotus.
              If it helps... the trunk is in the front of that Lotus...
              You're on your own from here on out, buddy. I'm happy to help, but I don't spoon feed. I've already done more thinking and searching for your project than you have yourself. It's your turn.
                Keep in mind that if you "hide" it too well, how you gonna get to it to jump start your car if needed? You could probably get one of those odessey batteries or a Braille battery and install it in the spare tire well. At least that way all you gotta do is lift up the carpet and floor board to access it.
                http://www.cb7tuner.com/vbb/showthre...=1#post1823428
                My Custom BB6 Dash Swap Thread
                  "my 2 cents"
                  If you get a small battery like that, you could hide it in your trunk surround.
                  If you don't know what I'm talking about, go into your trunk, left hand side(Jack is on the other).
                  Grab the top of the stiff fabric and pull it back. You'll see just plain metal. Put it there.
                  MRT
                  sneaky motherfucker
                    Make a custom plate with a hinge if your going to mount it behind the bumper so you can take the arms off and the plate will drop down with the battery on it.
                      Genius..I ALWAYS thought about relocating my battery to the rear of the car. It is entirely too annoying to have somebody try to get their car in a completely opposite direction just to jump start it.
                        Thanks. I'm glad people like us are smart enough to leave jumping posts, right?
                        MRT
                        sneaky motherfucker
                          Lol, you make it sound like a horrible task to just turn a car around...
                            lol might have to look into the odyssey batteries..
                            Ride List
                            1990 Accord dx coupe - my baby (dsm turbo set up in progress) http://www.cardomain.com/ride/3202853
                            2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
                            newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
                              Summit Racing carries them and Password Jdm makes a relocation kit for the EF that should work for a CB it goes inside the frame rail. You have to remove the battery tray.
                              http://passwordjdm.com/PasswordJDM-B...P1902C457.aspx
                              [IMG][/IMG]
                              MRT: http://www.cb7tuner.com/vbb/showthread.php?t=196248
