could the coolant temp sensor also make the idle jump up and down??
Another Idle Problem..
Originally posted by cb7runher View PostSrry guys problem still occurs. Could it be a brake booster gasket.
Putting block off plates on will no solve your problem.
The IACV is responsible for adjusting your idle when something puts a heavy load on the electrical system. It requires the normal idle to be set correctly though.
Measure the resistance across the IACV. It should be between 8 - 15 ohms.
Here's my problem idle thread, with just about every diagnostic thing you can do. It ended up being that I tightened the throttle cable too much.
http://www.cb7tuner.com/vbb/showthread.php?t=177619MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Ya the problem is weird I think I'm am going to change the booster gasket cause I replaced the booster awile back and the gasket had like a bubble in it and kinda peeling up. And I notice like sometimes once I release the brake it stops. Also when car is idleing the rpm will go up when I pump the brakes.Last edited by cb7runher; 06-07-2011, 02:57 PM.
Im still having a problem with my idle. I unplugged the vaccume line going into the fuel pressure regulator and the car started running perfect.. Does that mean i need a new one? Is that even a common problem
1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
Originally posted by keepinitcleanI give it 2 weeks before you sell it.
Both of you guys need to look for vacuum leaks, follow hondafan81s instructions for setting base idle, its a pretty sure fire way to show a leak. I'm on my phone so searching and posting the link is a nightmare, just search setting base idle.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
