could the coolant temp sensor also make the idle jump up and down??
Another Idle Problem..
Do you have power brakes?Originally posted by cb7runher View PostSrry guys problem still occurs. Could it be a brake booster gasket.
Putting block off plates on will no solve your problem.
The IACV is responsible for adjusting your idle when something puts a heavy load on the electrical system. It requires the normal idle to be set correctly though.
Measure the resistance across the IACV. It should be between 8 - 15 ohms.
Here's my problem idle thread, with just about every diagnostic thing you can do. It ended up being that I tightened the throttle cable too much.
http://www.cb7tuner.com/vbb/showthread.php?t=177619MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Ya the problem is weird I think I'm am going to change the booster gasket cause I replaced the booster awile back and the gasket had like a bubble in it and kinda peeling up. And I notice like sometimes once I release the brake it stops. Also when car is idleing the rpm will go up when I pump the brakes.Last edited by cb7runher; 06-07-2011, 02:57 PM.
Im still having a problem with my idle. I unplugged the vaccume line going into the fuel pressure regulator and the car started running perfect.. Does that mean i need a new one? Is that even a common problem
Originally posted by keepinitcleanI give it 2 weeks before you sell it.
Both of you guys need to look for vacuum leaks, follow hondafan81s instructions for setting base idle, its a pretty sure fire way to show a leak. I'm on my phone so searching and posting the link is a nightmare, just search setting base idle.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
