What else is powered by the cigarette lighter fuse?
    I accidentally shorted that circuit (long story), and I noticed the following things weren't working when I got home:
    Dome light
    Door lights
    Antenna
    Cigarette lighter
    To me that's an odd assortment of things to chain together.
    What else is there?
    It also powers the Key beeper
      What's the key beeper?
        When you leave your keys in the ignition and open the door.
        That beeping sound is the key beeper.
          When you turn the car off, leave the key in the ignition and open the door.
            I always thought there was just one speaker for blinkers and beepers. Are they separate?
              wtf
                Originally posted by g23 queen View Post
                I accidentally shorted that circuit (long story), ?
                what tribe do you rule? later.
                Avoiding dirt at all costs
                  This made me remember when i discovered the horn fuse was also connected to the BRAKE SWITCH.
                  The freakin brake switch! wtf
                  Car wont shift out of park? Check the horn fuse!
                    At least I can see why that would be plausible...
                    Reminds me when I had an HP Tech support person telling me to reseat the ram to fix a display backlight issue on a laptop. (Which by the way is absolutely bullshit)
                      You speak of late model chevy technology.
                        is it possible for a fuse to power some of those but not others? everything works except the key beeper doesnt work sometimes,other times it comes on 2 minutes after the door has been left open with keys
                        IG:worldboss_sanjcb7
                          The relay for the blinkers makes a sound that results from its mechanical operation.
                          The beeper for the door is a dedicated chime run by an electrical circuit.
                            the switch on your door might be bad.
                              might be a dumb question but where's the switch located, with the wires that run into it?
