So I read on an earlier post that a direct replacement alum. radiator (same size as stock). Would not benefit my car's preformance (1992 f22a1 5sp 4dr almost stock) because it might cool too good and the car could run below optemp. I live in the deep southwest and temperatures rise into the triple digit teens alot. I also live about an hour from every friggin thing and there is one helluva mountian range either way I go. I'm talking about a 4th gear balls out barely doing 60 up the top of the pass range. It's safe to say more semi's catch on fire at either the top or the bottom more than it rains a year here. Would a civic aluminium radiator with a say hayden fan to the trick? Does the same rule apply with all fan placement to make sure the fan is at least 1" away from fins to cool the most. Just wondering???????? I have more questions but I'm new and wouldn't want to annoy or take time away from your lives,jobs,families...........
cooling needs
You don't say..but are you overheating ??
What does a radiator and fan have to do with PERFORMANCE ? Why would you put a Civic radiator in an Accord ?
Your stock Honda fans with shrouds are better than any aftermarket fans.
The only reason to use aftermarket fans is if you stock Honda fans die and you don't have $15,000 to replace them. Or, you need the room.
People only use Civic radiators when they need room for a turbo. It's not a performance upgrade, it's a functional downgrade.
I would ensure that you have a quality thermostat installed, replace your radiator with a dual-core aluminum one (as said, the thermostat won't let you go below operating temp,) and run some coolant made for extreme conditions. Perhaps some RedLine Water Wetter.
Redline water wetter is an extreme condition coolant additive. Its normaly about one 12oz bottle to 3 to 5 gallons of coolant.
It helps prevent rust and helps with seals and low coolant hige water mixtures in high heat applications.
This sounds like it would be something you can benifit fromLast edited by Chris2388; 09-20-2011, 10:57 AM.
Originally posted by deevergote View PostI did not say it was an extreme condition coolant. It was an additional suggestion. If the OP takes the 15 seconds necessary to read and see what it does, he will understand that.
Ok Deevs I see that now I the see the SOME in there. Ill edit my post and just leave the info
If you are needing additives for your cooling system to make it cool better, then your cooling system is not up to par...you are just putting a bandaid on it.
Especially for a standard 4 cylinder motor.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Then get a dual core half radiator.Originally posted by esseyeguy View PostCivic radiators are .like half the size of our cb7 radiators I have a civic ef rad in mine now and it runs hot under extreme conditions ie. Dropping gear to pass someone lolWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
so a aftermarket civic aluminum radiator is cool? noone else has tried to fit the obx top mount manifold yet? i saw that there was some issues with the down pipe but not too worried about thatLast edited by bowtie_ethan; 09-21-2011, 08:53 PM.
92 CB7 F22 5 speed.
