Photo with questions
    Hi All
    Here, I have a photo of some items inside my engine bay.
    - the blue is something I found with a broken tip. It is made of some sort of har plastic, and has a hose that leads underneath the chassis or into the bay, I cannot confirm. -- This is my main concern, because IT IS broken. ( it's location is left side of rear mount/trans mount)
    - the orange is what I believe is the fuel filer location, and would like some help indentifying if so.
    - the green, I do not know what it is, and would like some info on what it is, and what it does. I discovered the little hose that connects underneath this canister was torn today, and I have replaced the hose.
    Thank you all for taking time to view/post.
    yellow correct
    the green is ur charcoal canister for ur gas tank. so that u dont smell gas fumes while ur driving and die.
    cant really see what u are pointing to in the blue its very grainy. perhaps a better pic. heater hoses control valve??
    (129)Transactions and counting
      It's very difficult to stick my iPad in there for a clearshot. Someone who could check their bay and see next to the rear motor mount would definatley know what that is .
        Originally posted by tommi View Post
        yellow correct
        Thanks for your response
          yes blue is a heater control valve.
          my new turbo build
            yes that is a heater control valve and it is expensive. i thought that mine was broken but it wasn't.
            1997 Ford Explorer V-6 AT (what a piece of junk)
            1993 Nissan Sentra M/T (front end damage, off road for now)
            1999 Mercury Mountaineer V-8 A/T - RIP (rolled: totaled)
            1992 Honda Accord A/T EX - RIP (transmission shot: sold to junkyard)
              What would this effect?? My heater works fine..
                Being able to close it or not.
                  my heater comes out barely warm even when all the way up, would this blue part have anything to do with it?
                  IG:worldboss_sanjcb7
                    Yes I jest replaced mine and now have a lot of heat.
                    Car safety checks
                    Fluid Capacities
                      To close what? My heater?? I'm sorry I don't understand. The actual device itself is in one whole piece, there's just the broken tip towards the front of the car. So as long as the device doesn't break, I'm fine??
                        They're not too expensive if you go aftermarket, about 40 bucks at Checker O'Reilly
                          honda lady is right. it is the heater control valve. its not a major fix, but can be expensive. you can do it yourself. I did mine. Removed the intake to get easier access. I also caution you to do this when your engine is cold. Coolant will leak when you replace it and you should do a coolant flush when done. You could just top it up too. Its two heater hoses, one on each side, and a few screws holding it in place to the firewall. Basicall when you turn the heater knob inside, the little weird shaped circle on top will turn, that allows coolant to flow to your heater core which will generate heat, its just like a shut off valve. Like i said, not major so you can go with it like that for now and shop around for a decent price. mine cost about $80.00 from part source and took me 30 mins to replace, had a hard time getting it off of the firewall.
                          Everyday is one day closer to completing my cb7 <3
                            Thanks for all of your responses Members! I'm just going to leave the piece for later fixing.
