Both will cause wear, but toe is what will eat your tires the fastest.
If you need to drive for work, and you need to drive this car, then I suggest you borrow money from someone to do what needs to be done. This is your life at stake here. Or someone else's... If you lose control due to worn or blown tires, you could be seriously hurt, seriously hurt someone else, or do some VERY expensive damage to your property, as well as someone else's. Not to mention your insurance will go through the roof, and you may even get tickets.
New tires and a proper alignment aren't cheap... but they're a hell of a lot cheaper than the alternative.
