Port & Polish intake manifold
    What's up everyone I'm new to the Cb7 forum so I have a few things I'm not sure about. Port and polishing the intake manifold is it worth it?
    I know people usual double stack the runners and all but I would like to hear what you guys say about it.
    If you have an F22A1/4 then spend the money on an H23 Intake manifold swap first, then go from there. If you have the F22A6 then look for an H23 plenum and throttle body. That should start you off in the right direction.
      Ya a H plenum is a dope ass mod especially if u double stack the iab plates.
      Love mine.
        My intake manifold has been ported, polished, and flowbalanced by CHR Racing. Pictures are in my MRT.
        Is it worth it? Probably not, unless the intake side of the head is being altered to match. The only reason I did it was because I have plans to port and polish my head, so when the time comes, it will be ready; and the fact that it was already off the car since I had to piece everything together for my a1 to a6 conversion.
          What gasket do u use on yours? Did u have to trim the gasket to fit since urs is all pimped out
            I just used the Bisimoto Phenolic Heat Shielding Intake Gasket, with a little bit of permatex grey around the coolant port. Then I used OEM Honda gaskets for everything else. The ports were gasket matched, then imperfections removed from each runner, flow balanced. I also have a "double stack", h23 plenum & tb (60mm) and my IAB's are wired up to my pt6. When I did the conversion it was like a whole new car! I was shocked at how much a difference in feel it made, and the sound. I still have the stock a1 airbox and factory a1 exhaust, and my intake can turn heads from 2-3 blocks away. My a1 never did that.
              What's gasket matched? Did he lay a oem gasket under the plenum, trace it, and ported it accord to spec?
                Thanks for the info, and I have a f22a6 and I plan on port and polishing the head as well
                  He used a blue dye to, and oem gaskets to see what needed to be adjusted. The main porting that was done was between the runners and the head, thats where the most material came off. Overlay an oem gasket to the ports on the intake, and you'll see what I mean.
                  Maybe some pictures will help:
                  Oh the numbers on each runner in blue are the flow numbers in cubic feet per minute (cfm), top number is with iab plate open, bottom is with them closed. It looks like max cfm without the iab plate to restrict is approximately 330cfm per runner.
                    Those are pretty decent numbers. Judging from some of the head flow charts it looks like this thing will quickly out perform the head it's attached to unless a good bit of porting is done to the head.
                      The F22A head flow numbers we all know / seen, are most likely from HondaFan's build, which CHR Racing performed the headwork for (same as my intake manifold). You would need one hell of a build to use another manifold, and if your needing those kind's of flow numbers, you might as well go ITB's.
                        These are posted on CD5Tuner.com:
                          ^^ That has been posted many times. The a6 manifold without the butterflys would flow around 330+ cfm on the intake side, which means you would need +2mm? oversized valves most likely to get flow numbers greater? Either that or revving to the moon...
                            And that F22A head was "budget ported". I have seen numbers north of 310cfm from a port and polish on an F22. I have yet to see the CNC portflow numbers, I'm sure they are north of 310cfm..... The builds that I have seen utilize that much flow have both been carb'd or individual throttle body induction as mentioned.
                            MR Thread
                            GhostAccord 2.4L Blog
                            by Chappy, on Flickr
                              With all this flow "IN" wouldn't the exhaust need to be ported, port matched, etc.. to support?
