I could really use some help guys, It'll save me a couple hundred dollars. I went to a shop today, lately the car has been having "flat spots" in acceleration where it hesitates. I have an after market fuel pressure regulator, and we thought it might have been the cause of the issue, the mechanic thought that the car was not getting gas. So we used all the original stuff, uninstalling the aftermarket regulator and using the original and the car ran like crap. When he squeezed the return fuel line, the car revd up fine. He suggested that the fuel pump may be bad... this is after trying two original fuel pressure regulators.
prior to my car having this trouble or hesitation in acceleration, I used a bottle of forumula1 carb cleaner, an additive that you put in your tank...I'm thinking carb build up in the egr as result of the additive. The mechanic also said that the egr would not cause the car to act up as in hesitation and accelerating. What do you guys think from your experience, should I go ahead and replace the pump or clean the egr first?
