I don't even know what this thing is called... the radiator has two little plastic knobs on top that fit into holes in the radiator brackets, and hold the top of the radiator in place. One of mine broke off, so I glued it back on. Now it's broken off again. It's not a huge problem, the radiator isn't going anywhere, but it just offends my sensibilities. I was thinking of threading a zip tie or two through the radiator mesh, over the top and through the bracket... is there a better way to fix it? (No, I'm not gonna buy a new radiator.)
Broken "nipple" on top corner of radiator
I would not run anything through the "mesh", it is relatively fragile - if you damage it a cause a leak, then you will have to replace the radiator. The other option would be to fashion a rubber block of some kind to fit over the top tank of the radiator under the bracket and use an adhesive to glue the block to the underside of the rubber grommet in the bracket.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
