Ok, so my antifreeze keeps leaking but I have no idea from where or how? I've replaced all of the thermostat, all the hoses(one had a cut), and I checked to see if everything's intact properly and all looks good. However Ive wasted almost 3 bottles of antifreeze because every other week the reserve tank and the radiator is low and my car over heats? Any ideas?
Antifreeze keeps leaking!
Start looking under the car for leaks?Originally posted by iiball3 View PostOk, so my antifreeze keeps leaking but I have no idea from where or how? I've replaced all of the thermostat, all the hoses(one had a cut), and I checked to see if everything's intact properly and all looks good. However Ive wasted almost 3 bottles of antifreeze because every other week the reserve tank and the radiator is low and my car over heats? Any ideas?
we cant really help you, all we can do is guess.
Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Check your oil or your exhaust pipe. If it's not on the ground, it's in one of those places.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Does your car spew out white smoke in the mornings, and im not talking about condensation smoke.Originally posted by iiball3 View PostHmm.?.my flex pipe is cracked from the front and air is leaking out...I doubt this has anything to do with it tho?Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Most likely its a blown head gasket....sowwyOriginally posted by iiball3 View PostYessssss. I seen it 3 days ago. Comes from the flex. Shots cracked since jersey roads suck and my shits dropped.
You can verify with this:
http://www.amazon.com/LISLE-75500-CO.../dp/B0002KPZ2QLast edited by dj_ender; 04-13-2012, 11:38 PM.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
I mean I started it up one day and seen smoke come from the middle of the front passenger door...then it stopped. I haven't seen it back since. But I looked under the car and saw my flex was cracked and air was coming out. Still think its that?Originally posted by dj_ender View PostMost likely its a blown head gasket....sowwy
If it only did it once, then no. You need to take flashlight to the engine bay and under carriage and find where it's going.Originally posted by iiball3 View PostI mean I started it up one day and seen smoke come from the middle of the front passenger door...then it stopped. I haven't seen it back since. But I looked under the car and saw my flex was cracked and air was coming out. Still think its that?Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Tanks. I'll check tomorrow and let you guys know if I need further help. Any other physical signs to tell if it's the head gasket?Originally posted by dj_ender View PostIf it only did it once, then no. You need to take flashlight to the engine bay and under carriage and find where it's going.
Not that I can think of, if the head gasket is leaking you'll be seeing smoke come out at every morning start up. Your either leaking it, or burning it, and from the sounds of it, your not burning it.Originally posted by iiball3 View PostTanks. I'll check tomorrow and let you guys know if I need further help. Any other physical signs to tell if it's the head gasket?
Does the inside of the car smell sweet, like coolant? You can always put a larger piece of cardboard or paper under the car over night, if its leaking you'll see it.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Actually no, I can't smell anything. I've read some symptoms and my oil is fine, no milky stuff. And def. no white smoke coming from the exhaust, even if my flex is cracked I would see a constant white smoke, but I don't. Must be something small. I'll check the radiator if it's cracked? But the only thig is a bottle of coolant last me for like 1-2 wks?Originally posted by dj_ender View PostNot that I can think of, if the head gasket is leaking you'll be seeing smoke come out at every morning start up. Your either leaking it, or burning it, and from the sounds of it, your not burning it.
