Originally posted by iiball3
View Post
Antifreeze keeps leaking!
mine had i blown head gasket . it wouldn't smoke unless i rev it .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
I think your leaking it, put something under the car over night like I suggested and then you will at least get a general area to start looking.Originally posted by iiball3 View PostI never seen any smoke, only that one morning I started it up..but it was for 2 secconds, when I came out it went away?Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
no i had to take it up to 4k . 5k it really smoked .Originally posted by dj_ender View PostBut you still saw it when you drove, correct?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Crazy, mine does that at 5k as well, but its rings. Your leak must have been fairly small.Originally posted by Accord problems View Postno i had to take it up to 4k . 5k it really smoked .Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
That would probably be just steam. Even my car lets out a little cloud of steam when i first start her up. It is really noticeable after i installed the WS2 but yeah it goes away after a few seconds of running.Originally posted by iiball3 View PostI never seen any smoke, only that one morning I started it up..but it was for 2 secconds, when I came out it went away?
I'd just check around the radiator because most of them are have an aluminum core but plastic almost everything else.
By any chance have you checked the lines going to the heater? i think there is a valve that opens and closes that goes bad.
na i couple of hours of driveing in the summer and still did it . i went through a lot of coolent . and did the same at winter time .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
mine was leaking like crazy so i just took it to a radiator shop and they found like 1 broken hoe, and 1 cracked one but they were way in the back where i couldnt reach em it looked like a bad time so i just paid them to do it,$40. sucked but saved me the hassle. then 2 weeks went by and as sson as i got to work i noticed alot of steam coming out from the hood and turns out another hose had busted. paid $15 for that one but that one was easy so i did it. point is get it checked out by someone wheo knows about shit like that. dont like to normally do that becasue i dont like anyone working on my cb7 other than me but if your tired of the bs just take it in. best advise i can give to you.
mine was the gasket . when it went down it had nothing left from that side and smoked at idle on its last day of life .Originally posted by dj_ender View PostCrazy, mine does that at 5k as well, but its rings. Your leak must have been fairly small.Last edited by Accord problems; 05-03-2012, 03:26 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
