Ok so I attempted wiring vtec yesterday and it didn't turn out quite like I'd hoped.. I have swapped to a 96' f22b1, running a1 injectors and distributer with my original 91 ecu and she runs just fine w/o vtec.. no CEL.... then I go switch a6 & a11 pins, vtec-a4, vtec pressure switch -d6 and 94' POA ecu... starts but runs like shit, erratic idle and CEL.. took it for a spin and there's a nasty jerk around 4k. Even earlier(3k) if I lean on the pedal.. IM STUMPED!
b1 v-tec problem
What codes are you getting (CEL) That would be as good a place as any to start. You can use the same paperclip SCS short method to retrieve the codes as your regular ECU.
Sounds like your having VTEC issues. It kicks in anywhere between 2300-3200 rpm if the actuation conditions are met and the ECU sends the signal to the solenoid. Check all of your ECU pins and make sure they are in good and tight.
If it runs fine with the PT3, and poorly with the P0A, then the issue definitely seems to be in your VTEC wiring. Check for exposed wires, bad splices or solder points, etc... Make SURE all your wiring is correct (take pictures if you're not sure, and someone will certainly be able to help.)
The PT3 isn't looking for the circuits involved in the VTEC system, so that being the only real variable in this situation, that's probably where the problem is.
The other potential problem is that your P0A is shot. Do you have access to another?
Originally posted by deevergote View PostIf it runs fine on one ECU, I'd assume that they are.
