I am new here....and I am also new to CB7's lol I always owned Civics... anyway, I bought my CB7 about a good two months ago, and I have replaced quite a few things. My issue is now I have an oil light that only flickers every so often, I am only a quart low, and i just replaced my oil pressure sending unit. Could someone PLEASE help me out?
Oil Light Flickering
Put a quart of oil in it then comeback if the issue continues.
02 Crv
If you are a quart low then yes put a quart in it.1993 10th Anniversary MRT
Originally posted by The G-ManFor that money, yes. But my dick isn't big enough for that shit.
List of all my cars to date
Next time could you please title your thread properly otherwise it will be deleted.Originally posted by CB7uner View PostI am new here....and I am also new to CB7's lol I always owned Civics... anyway, I bought my CB7 about a good two months ago, and I have replaced quite a few things. My issue is now I have an oil light that only flickers every so often, I am only a quart low, and i just replaced my oil pressure sending unit. Could someone PLEASE help me out?
Refill your oil to the correct level and recheck it.
My 5.7 LS1 Holden Ute
A quart low from what level? From maximum level? or From minimum level?
Are you in normal operating temp when the light flickers?
At what RPM does it occur?
If flickering occurs with oil level above minimum level on dip stick, when hot and when rpm is at idle, I would change oil to higher viscosity oil.A&P-IA
