My MAP sensor started throwing a code 3 so i have been spending my spare time tracing the only wire that i don't get a voltage from. i assume this is the wire i have a short in but i have yet to find a break in it but when i traced it back to the ecu i noticed the clip is a little banged up but the pins seem in good shape. is there anything else i should be looking into about this issue that im not thinking of? i do have a swap so i can only assume the loom was molested at least to add the vtec wiring etc. or could it be a bad ecu in general?
MAP sensor issues
check to see if your geting it from the ecu.Originally posted by Loghead View PostMy MAP sensor started throwing a code 3 so i have been spending my spare time tracing the only wire that i don't get a voltage from. i assume this is the wire i have a short in but i have yet to find a break in it but when i traced it back to the ecu i noticed the clip is a little banged up but the pins seem in good shape. is there anything else i should be looking into about this issue that im not thinking of? i do have a swap so i can only assume the loom was molested at least to add the vtec wiring etc. or could it be a bad ecu in general?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
