Blinker switch not working ARGH!!!!!!!
    anyone else had their blinker switch break??? mine broke about a month ago right where the lever meets the steering wheel i could still use my blinkers and lights but last night apparently it froze or something i have no lights no blinkers just high beams. it simply won't move up or down and the switch for the lights still clicks light it should but my lights won't come on. basically i am wanting to know if it's a common problem and if it's an easy fix thanks
    Fairly easy to fix. The only bummer part is removing the steering wheel and whatnot, you have to do that in order to remove the lever assembly. Just hit up the JY for an assembly and do what it do.
      figures the uncommon stuff that breaks in this thing is always the most tedious thing to fix anyway what is JY????
        JY is a junkyard. There are tons of our generation Accords in junkyards making this mostly a non-issue as the part is extremely easy to come by. There's no reason for the typed-out frustration and whining. It's a 20 year-old car and stuff happens. If that's the only thing wrong with your car then consider yourself blessed.
          if u got enough skills u can do it with out removing the steering wheel. i knoww i did. its only 2 screws. (it been a while maybe 3 screws) but an easy job
          honda life 4218
            I had the turn signal in my wagon fail ON while driving home from FL in May, something in the switch fried and actually melted the housing. As Zay said, it can be changed out without removing the steering wheel. There are three(?) screws from underneath that hold the steering column upper and lower covers on. Then you should be able to get to the two screws that hold the switch housing in place, use a long screwdriver threaded through the steering wheel.
