How will I know when my inner CV joint goes?
    It's quickly becoming inevitable. There is no boot on it.
    Will I hear clicking, or something else to indicate it's time?
    MRT
    sneaky motherfucker
    You'll hear it click when you turn then it will start clicking constantly..... thats what happened to mine. I replaced it before it got any worse
      The outer cv joint clicks when you turn the inner joint slides in and out, jack up your car and twist the tire until it fetches up and watch the axle and joint, too much play may mean time to change it
      My work in progress!
        No boot means it's time to change it.
          x2 For sure. I can imagine all the grease that its slung all over the place. That has to be nasty.
            Actually, it was a new boot. The clamp slipped off and the boot shredded itself.
            As a precaution, I snipped the rest of the boot off. Precaution, because when
            the clamp slipped off, it hit a wire on a sensor and cost me $100.
            I doubt it'll click. The clicking comes from turning, which is what the outer joint
            does. This just slides in and out.
            MRT
            sneaky motherfucker
              When it turns into metal shavings.
              Just replace it.
              My 5.7 LS1 Holden Ute
