I doubt it's the o2 otherwise I'd have a CEL like in it's early years when it had o2 problems.
Misfire Problems
That is not true man. I have read a few guys on here have had bad o2 sensors and they will not throw the code. So if it looks old and you are not sure if it has been replaced in the last 19+ years i would go ahead and try it. Mine was 29.95 from a local auto warehouse and its a denso as well.Originally posted by Vistaman73 View PostI doubt it's the o2 otherwise I'd have a CEL like in it's early years when it had o2 problems.
Read my post prior to that one. I was talking to a friend of mine and he said he had the same problem and it turned out to be the coolant temp sensor which was mentioned earlier in the thread. If it is bad it can keep the engine from going closed loop and make it run rich (like i does when warming up) which is why it ran fine cold but missed and ran rich when warm. I unplugged the sensor and it ran great although my CEL was on and my Sports light was flashing lol. I'm heading up to the auto store soon (when I have enough money) to get a new sensor. Thanks for all the help and suggestions everyone, I'll give you a final update when I install the new sensor.
$40 for a new sensor. Still does it. I'm at a a loss. It misses by running rich with it plugged in (both new and old sensors) but doesn't with it unplugged. But then my CEL is on and doesn't want to start in the morning cause it doesn't know it's cold so it doesn't richen the A/F Ratio. Maybe it's my ECU? I can get a another one cheap. It'll be the one from a prelude.
Map sensor. That's my guess. I'm not 100% sure though.Originally posted by Vistaman73 View Post$40 for a new sensor. Still does it. I'm at a a loss. It misses by running rich with it plugged in (both new and old sensors) but doesn't with it unplugged. But then my CEL is on and doesn't want to start in the morning cause it doesn't know it's cold so it doesn't richen the A/F Ratio. Maybe it's my ECU? I can get a another one cheap. It'll be the one from a prelude.The Lord watches over me!
- D. Chappelle
It's a 91 I didn't think they had MAP? Or am I mistaking this for another sensor my car doesn't have? LOL
EDIT: Yep, I had a brain fart. I don't have a MAF. What would a faulty MAP sensor do?Last edited by Vistaman73; 08-04-2012, 01:17 PM.
The MAP sensor is inside that black plastic box by the passenger's firewall.Originally posted by Vistaman73 View PostIt's a 91 I didn't think they had MAP? Or am I mistaking this for another sensor my car doesn't have? LOL
What year CB7, 91 I think you said, then it is OBD I? OBD I codes don't do anything for misfire just emissions control. When was the last time the plugs, wires, and dist cap was serviced for a tune up? Could be very simple fix there!
1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
It's not running fine, most likely it is running rich when you unplug and going into limp mode dumping more fuel and hiding the problem by being inefficient.1993 SE Coupe MRT - 1992 LX Sedan MRT
did you get this resolved by any chance?
i dont get any cel light
my cb7 is doing the same thing i suspect the the o2 sensor.
edit i caused a cel so it could run in closed loop mode and it still does it
but it idles and stars up fine as soon as i stomp then pure hesitation
ThanksLast edited by networknewbie; 08-14-2012, 05:49 PM.
You may very well feel that it isn't the O2 sensor - but you may still give it a try. I chased after a very similar problem & the car would not throw a code. Mentioned the problem to a friend who had work in a GM garage & he recommended unhooking the O2 sensor & so I did. It did take the miss & nasty stumbling out - as to why it never threw a code is beyond me. Replaced the sensor & the car ran fine with everything hooked up once again.Originally posted by 1991redcoupe View PostWhen mine had a similar problem it turned out to be the o2 sensor.....disconnect and see if problem persists
