i did a brake pad change on my front brakes, MY car started bouncing alot when i was done it didn't use to do that. i picked my car with a floor jack and put floor stands on both sides so i could finish fast. i have stock suspension and i maked sure the wheels where properly installed. i do have bad axles but i don't think that's the problem. i really don't know what's wrong. Also when i took off the stands the passenger side front was really low i think maybe the shocks were bad and as i raised it it probably messed it up. anybody know what might be the problem.
suspension front passenger
Sounds like the " Bouncing alot " is from blown out shock/strut on the front . Did you release the floor jack really fast ? If so, it may have blown it completely out .
If I were you I would replace the front shocks a.s.a.p. to prevent wrecking
is it bouncing when hitting the brakes? you may have warped your rotors or damaged your suspension by not going by the book and lifting/dropping the vehicle properly or torquing the bolts correctly. *WARNING NOT A SAFE RECOMMENDATION FOLLOWING* with the car well supported on jack stands or blocks (not a jack) in the front and wheel chocks on the back what do the wheels do when you put it in drive? Also your "bad axels" could be causing binding... just saying don't rule them out.Last edited by wildBill83; 08-04-2012, 05:11 PM.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Sure it can, I have seen it on many makes and models of vehicles. And he could have warped them by installing improperly, not lifting the car.
Examples:
http://wiki.answers.com/Q/Why_does_m...ply_the_brakes
http://www.fixya.com/cars/t3897436-a...brakes_bouncesLast edited by wildBill83; 08-04-2012, 07:09 PM.1993 SE Coupe MRT - 1992 LX Sedan MRT
All he did was changing pads. How much force does he need to apply against the rotors in order to warp them? On my LX, I had a hydraulic jack under the rotor and dust plate supporting weight while I had to re-position the jack stand. That rotor didn't get warped. The loading was vertical not horizontal but it shows how strong the rotor is.
Change words to "vibrate" from "bounce" on those questions/links and I will believe them. Based on my personal experiences, I never had bouncy car due to warped brake rotor(s) .Last edited by oyajicool; 08-07-2012, 09:30 AM.A&P-IA
The car is on 20 year old shocks. It's reasonable to assume that they are blown. The fact that it became noticeable after the car was jacked up for a brake job is pretty irrelevant. The only effect the raising of the car could have is to allow the shock to extend further than it had while the car was sitting on the ground. What little pressure may have remained in the shock may have been lost by that extra stretch.
Bottom line, replace your shocks. Replace your axles. Replace any other worn suspension component you come across.
Sounds like blown shocks but also if the passenger side is sitting lower then you might have a broke spring. I would do a complete suspension look over... just my 2centsOriginally posted by mexitex13 View Posti did a brake pad change on my front brakes, MY car started bouncing alot when i was done it didn't use to do that. i picked my car with a floor jack and put floor stands on both sides so i could finish fast. i have stock suspension and i maked sure the wheels where properly installed. i do have bad axles but i don't think that's the problem. i really don't know what's wrong. Also when i took off the stands the passenger side front was really low i think maybe the shocks were bad and as i raised it it probably messed it up. anybody know what might be the problem.
BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
n thanks for the tips I learned something.
