Malfunctioning Gauge Cluster
    It's completely random,
    ~I turn the car on drive a little and all the door lights come on..
    ~I start the car and it comes on immediately..
    Anyone else having this problem and what does it mean...
    Hell Yes I have this problem. It drives me nuts but I've gotten used to it. I think It prob has something to do with the cluster itself.
    I had retrofitted a bb6 cluster and never had any trouble with the lights. Also my manual cluster broke so I had to get an auto.
    So My situation may be a little different.
    I plan to take it apart and clean the contacts and put some electrical grease on the connections at some point.
    steve
      I've seen some pictures of clusters, where the traces on the back/connections have portions that look "abnormal". It also could be an issue similiar to our main relays, and the solder points are not making good contact. Either way, the problem is most likely the cluster itself. Either replace it with another known working one, or figure out what exactly is the issue with your cluster, and fix it.
      For the first scenario of the traces, they could be fixed by running a wire between the two contacts (re-establishing the connection). For the second scenario its just desoldering and resoldering.
      Maybe this will help:
      If you need any other electrical diagrams, they can be found here: [INFO] Chassis Electrical System - Typical Wiring Diagram Scans
        I experienced this issue 2 years ago. Here is the Thread below. this should help you out in your situation.
        http://www.cb7tuner.com/vbb/showthre...or+ajar+lights
