ECT sensor - H22 swap
    Originally posted by GhostAccord View Post
    3.6v from the ECU is not what you want. You want to see 5v at both the sensor and the ECU on the (+) wire. Sorry I left that out!
    You need to back probe the ECU @ pins D13 (+5v) & D22 (-).
    I probed wires d13 and d22, key on, right behind the ecu clip. 3.6volts is what its showing.
      Should be approx. 5v... I don't consider 3.6v as approx 5v..... Do you know anyone with another ECU you can try?
      MR Thread
      GhostAccord 2.4L Blog
      by Chappy, on Flickr
        To ensure Ive done this right - I probed d13 with the positive probe and d22 with the negative and got the 3.6. Just want to make sure I wasnt supposed to ground to chassis or something when checking the +5v.
        Im trying to source a p13 locally as we speak. Hopefully I can track one down.
          That is the correct procedure!
          MR Thread
            Im having a hard time sourcing a p13 to use. However, a friend of mine does have a chipped p28, and can put a base map in for it. Would that be sufficient? Also a p06 is available.
              Any known good working ECU should work. If your friend can monitor/datalog the chipped ECU that would be even better.
              MR Thread
                All of these ecus Im finding are confusing. Are all obd 1 ecus interchangeable? I know the p06 will run SOHC d series motors. Is it good enough to diagnose this ect issue?
                Sorry about all these questions. Im fairly new to the honda game.
