Braking problem need help
    ok what's good FAM
    I been having problem with my brake system...when I'm driving and i need to slam on my brakes due to morons on the street or racing on the track ..i press the brake paddles to the floor and my cb7 doesn't slow down fast enough i have replace the master cylinder with a new one. It is still happening.. brake pads still have another 10,000 miles on them ...
    the setup I have is 93 LX front calibers/disc that came with my cb7 and 92 ex caliber/disc swap
    Half of the time I have to pull on my Ebrake because I'm not stopping fast enough
    need help thanks in Advance for the help
    Either there's air in the system or you are driving too fast.
    A&P-IA
      lol me and the shop have both bleed the system both by hand and vacuum....and you can never go too fast lmao
        maybe you should un break your brakes? lol
        does the pedal feel spongy or soft? does it go all the way to the floor? it should be high and firm and your 91 doesn't have ABS so slamming the pedal would cause the car to lock up the brakes and it would skid, best way to slow down faster is rapidly pump them... push down and when you feel the car start to skid let up and reapply and repeat
        MRT http://www.cb7tuner.com/vbb/showthread.php?t=188701
          isn't there a difference in the prop valve also? i swore that a lot of people who convert their rear drums to discs also swap the 40/40 prop valve from an Integra.
          http://www.cb7tuner.com/vbb/showthre...isc+conversion
            Lmao i fix misspell....and my 93 LX didn't come with ABS..and yea it does feel a bit stiff spongy that leads to the floor when braking at fast speed
              well Leung..this been happening way before i did the swap from drums the disc
                well if it is spongy at fist and then falls to the floor you have a leaking seal in your master cylinder... if you have already replaced it and it is still happening its because your brake booster probably needs to be replaced and it is sucking the fluid out of the master and burning it in the engine... pull the vacuum line off the booster and if there is fluid in the line that's your problem, you'll need to replace it and also the master cylinder it just ruined... hope that helps
                  aight ill try that and if any one else has anyother idea lmk
                    ok i just check the brake booster vacuum line like Nyne521 stated and the line has no fluids or any sign of liquid so is not the brake booster
                      I would also check slave cylinders and fluid levels, is fluid dissapearing?
                        What pads are you using? What rotors? Have the rotors been resurfaced or replaced with the last pad install?
                        When you did the rear disc install, did you use a 40/40 prop valve, or did you just bolt up the new brakes? The proportioning is not going to be correct if that's all you did.
                        If you're racing this car on the track, or driving like a dumbass on the street, then it's entirely possible that you've glazed your rotors and pads. Or that you simply overheat street pads beyond their abilities, causing severe brake fade.
                        OR your expectations of this vehicle are too high. The braking system is designed for casual street driving, not racing. You can't drive it like a Lotus and expect it to hold up.
                        Please actually ANSWER the questions people are asking you if you want help. We can't help you with the limited information you have given.
                          yes the rotor are stock and resurface when i god no pads, i have ceramic pads, no i didn't use the 40/40 prob valve, and no I'm not driving like a dumbass on the street (idk if you ever been to florida but people down here can't drive for shit) I race my cb7 every once in a blue moon at the local track rather than the streets as i stated on the first post, and I have been answering everyones question the only i haven't answers is wildBill83 which i goin to do next btw
                            i check the fluid levels this morning and its still full
                              What order did you bleed the lines? Can you give us full details of EXACTLY what you did and was the problem there before your brake job?
