Hi all,
I recently noticed while sitting at a stop light that the temp gauge started creeping up on my 93 SE. As soon as I started moving again, the temp dropped back down to normal (~1/2 on the gauge). If I keep the heater turned all the way to hot, I have not seen it overheat at all, whether the blower is on or off.
My first thought was thermostat, even though I should have probably thought otherwise since when I checked the hoses the first time I saw this problem, both upper and lower rad hoses were hot. Regardless, I installed a new thermo, and the temp still creeps up if I'm sitting still with the temp dial set to cold.
I am now thinking it is the radiator fan, since I have not been seen or heard the fan run either with the car running, or after I turn the car off. If I turn on the A/C, both rad fans spin (passenger side and driver side) so I know the motor isn't bad.
I believe this leaves me with the two fan switches, and the relay, right? Is the fact that neither switch seems to be working (car on vs. car off) a hint that it might be the relay, and if so, is there a way to test that? Or should I just start replacing switches, and then move on to the relay if that doesn't fix things?
Also as additional information, the water pump is fairly new (4 years old, maybe 30,000 miles?) and the previous thermostat was <1 year old. I bled the coolant after changing the thermostat this latest time.
Thanks
Thanks
