Hey guys ive searched and searched but i cant seem to find out where the cooling fan timer is on my '91. The problem is the fan turns on and stay on after i pull my key out of the ignition, i dont even have to turn the car on for this to happen. But the end result is a dead battery. But anyway, from what ive read its a small black box under the dash. I see two small black boxes, one just above the fuse area, and one on the other side toward the center of the dash. Ive checked online and even called my local Auto Parts store to get a replacement and to figure which it is but they dont have anything of the sort so im confused
Cooling fan problem
I'm having a cooling fan problem myself, only my fans don't turn on unless I run my A/C and it never comes on after I turn the car off.
Not sure about under the dash, but under the hood near windsheild, passenger side, there is a black fuse box. Open that up and you'll see the fuse for the fans and a relay for the fans. I imagine your fuse is good as the fan turns on, but your relay could be damaged.
You will see the fan relay and the power window relay side by side. They are the same relay so to see if that is the problem just switch relays. Your power windows should still work, as your fan. Maybe it will shut off.
If not the relay there are 2 temperature switches that sit in the coolent on the motor. One on the motor where the coolent line goes out to the rad in front of the distributor, and the other down low where the coolent returns from the rad. One switch turns on the fan after the ignition is shut off for one minute, the other switch turns on the fans as you are driving at low speed when the temp goes up.
I just bought both switches but I forget which one is what.
Part number for your switch is either TS187 or TS254. Maybe it is faulty and turning on the fan but not shutting it off.
I'm still troubleshooting mine so not sure if I nailed it yet. Switch is about $40.
thats them . ok one black box is a timer for when the car is running . the other is for when the car ( ignition switch ) is off . your best off replacing booth . it can also be a bad temperature switch .
edit use the search bar for this web site . type in Radiator cooling fan not working...Last edited by Accord problems; 05-21-2013, 10:08 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Accord problems View Postthats them . ok one black box is a timer for when the car is running . the other is for when the car ( ignition switch ) is off . your best off replacing booth . it can also be a bad temperature switch .
the two black boxes he was referring to are the timers for the cooling system . when they fail some will keep the fans on till the battery dies or not come on at all . and yes op they are above the fuses box by the kick panel .Originally posted by 91CB7Leo View PostThanks for clearing it up, i guess ill have to try the dealer or the junkyard for the parts thoughLast edited by Accord problems; 05-21-2013, 10:19 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Accord problems View Postthe two black boxes he was referring to are the timers for the cooling system . when they fail some will keep the fans on till the battery dies or not come on at all . and yes op they are above the fuses box by the kick panel . try the junk yard first or fined a friend that has a known good cb7 and ask to try his then decide if you should go to the dealer .
op your welcome .Originally posted by 91CB7Leo View PostThanks for clearing it up, i guess ill have to try the dealer or the junkyard for the parts thoughOriginally posted by Ispintechno View PostI'm confused, you guys say there are fuses inside the cabin of the car? I found mine under the hood. Mine is a 1990, not sure if different?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by 91CB7Leo View PostLast edited by Accord problems; 05-21-2013, 10:54 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Ispintechno View PostWell I`ll be a Monkey`s Uncle... didn`t find that. Been fiddling under the hood and thought what was what was under there...this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
ok the other parts im talking about are located in side the car . parts you aint bought yet .
check this out http://search.mywebsearch.com/mywebs...&ord=15&ct=AR&Last edited by Accord problems; 05-21-2013, 11:17 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
