I am looking for anything that i can pour into my oil or something that will stop my car from smoking no permanently i know. My car smokes HELLLLALALLLAA like so much its crazy. Its not the head. It could be the rings but it smokes like CRAZY!!! and there is so much air being blown out of the valve cover when i take off the oil cap. And the car runs FINE. PERFECT! but smokes SOOOO much.
Stop my car from smoking CHEAP?
It is the head. Your valve seats are bad. There is no magic oil leak stop liquid you can pour into your oil. Nothing short of rebuild will stop massive smoke in the exhaust.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Its not the head. I bought a new head and i also rebuilt my old head. All new valves... Seated... fully cleaned and everything lol.Originally posted by wildBill83 View PostIt is the head. Your valve seats are bad. There is no magic oil leak stop liquid you can pour into your oil. Nothing short of rebuild will stop massive smoke in the exhaust.
Engine repair does not come in a bottle. Period.
oyajicool's suggest of Marvel Mystery Oil (MMO... use the full name... noobs don't understand these things...) might help if it's a matter of something being stuck, but with a 20+ year old engine, it's unlikely. It's most likely worn out or broken.
Are you actually going to reply to this thread, or are you going to ignore it like you did your other one about an engine swap? Sooner or later, people are going to stop answering your questions if they feel like they're just pissing into the wind.
Then it is your piston rings or you installed the head gasket wrong. What are your compression test numbers? Did you do the work yourself? Did you have the head machined? What was the reason you rebuilt your head?Originally posted by buyars View PostIts not the head. I bought a new head and i also rebuilt my old head. All new valves... Seated... fully cleaned and everything lol.
I assume he is burning oil because in the OP he discusses something to add to the oil.1993 SE Coupe MRT - 1992 LX Sedan MRT
