Hey guys, I'm having a problem with starting my car. I can start it by popping the clutch by a roll start. I've replaced the battery and I've replaced the starter. I checked the voltage at all related fuses and the one that is showing nothing is the starter signal fuse 7.5 amp located under the dash at the drivers kick panel. I've replaced that fuse 2 times but both were good. I tested the sides of the fuse with a multi meter and I'm not getting any voltage at any of the 2 sides. Doesn't matter if the car is ignition switch off, on or car running (once clutch popped) Does this mean that the ignition switch is bad? I've never had a problem before and it just started last night. The car is a 91 4 door Honda accord 2.2 fully stock. Any help would be so appreciated. Thanks
starter signal issue please help!
I would check the output from the main relay, then input to the main relay, then at the very least your ignition switch at the end of the line. If you need schematics send me a PM. I sometimes miss threads and I am not the best at going back and posting up info if I forget about it.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
The main relay deals with the fuel pump. If it will run with a push start, it's not the main relay.
I had an issue like that years ago, and after replacing the starter and battery, I discovered that the problem was due to corrosion on my battery cables. I cleaned the connections, and all was fine again. Check/clean/tighten all battery connections and grounds.
If the battery and ground connections aren't the issue, then look at the ignition switch.
Thanks for the quick reply guys. I'm having the same issue this fellow had
http://www.cb7tuner.com/vbb/showthread.php?t=192639
I noticed after reading around on here that it can be the neutral safety switch, cause I saw 2 blue pieces of plastic on the floor. I guess I will use the paper clip trick first to see if it cranks up?
Right after I bought mine back in February I had the same thing happen. I replaced the starter as you did and it still didn't turn over. While I was tracing the wires that go to the starter I found it had a heavily corroded ground wire. I cleaned it off with a wire brush, put a little grease on it, put the bolt back through it and it started right up.
Originally posted by 2tonecoupegrl View PostThanks for the quick reply guys. I'm having the same issue this fellow had
Try the paper clip and if it starts replace the pin.
Originally posted by ferenza View PostThat might be the pin that pushes the neutral safety switch in.
Originally posted by DemoDerby112 View PostIf all else fails you can always run a push button pretty easy. Wire from pos terminal to button and another from button to the small wire on starter.
Originally posted by 2winRB25 View PostRight after I bought mine back in February I had the same thing happen. I replaced the starter as you did and it still didn't turn over. While I was tracing the wires that go to the starter I found it had a heavily corroded ground wire. I cleaned it off with a wire brush, put a little grease on it, put the bolt back through it and it started right up.
Not only the battery terminals but follow the ground cable off the battery to where it bolts to the chassis/unibody.
It wouldn't be a bad idea to do the same for the positive side either.
Also go through both fuse boxes (in car and under hood) and make sure no fuses are blown.
By the way, I have an S14 too! I have a white 1997 with an RB25DET from an R33 Skyline.Last edited by 2winRB25; 07-07-2013, 03:40 PM.
Hey, yeah I checked every single thing I could think to. Since the db7 is my daily I needed get her fixed asap. I ended up by-passing the starter signal wire and running a hardwire setup with a super duty momentary ignition switch. She's back to starting like a champ now (plus since I ended up running the switch its now hidden) so that's kinda cool.
I saw your s/n and thought hey skyline motor... that's cool Kouki's are nice front ends I also have a 2 tone coupe IE my s/n LOL
Originally posted by 2tonecoupegrl View PostHey, yeah I checked every single thing I could think to. Since the db7 is my daily I needed get her fixed asap. I ended up by-passing the starter signal wire and running a hardwire setup with a super duty momentary ignition switch. She's back to starting like a champ now (plus since I ended up running the switch its now hidden) so that's kinda cool.
And yeah, My 240 isn't anything special other than the motor. Its just a stock RB25DET with the boost turned up a little. Bone stock other than that. Looks bone stock too which is cool because people under estimate it on the street. When it breaks loose at the end of second and they hear the whistle they realize what they have ran across.
Yeah I also left the neutral safety switch out since I no longer need it and always keep the shifter in zero gear, took the 7.5 fuse out of the SJC and moved the OEM starter signal wire away and wrapped safe. Another cool thing about the way its setup now is it will reduce lifeware of everything clutch related.
stock/sleeper is good for messing with people, then you let it rip. Are you running around 12psi?
Originally posted by 2tonecoupegrl View PostYeah I also left the neutral safety switch out since I no longer need it and always keep the shifter in zero gear, took the 7.5 fuse out of the SJC and moved the OEM starter signal wire away and wrapped safe. Another cool thing about the way its setup now is it will reduce lifeware of everything clutch related.
