Hi im new to cb7 I traded my ef hatch for it and it has a vibration when im at a stop at idle its a 91 se model all stock any insight I think it might be mounts but I could be wrong any help is appreciated.
Vibration while at D4 idle
Its the mounts probably the rear mount.Originally posted by CB7NOOB310 View PostHi im new to cb7 I traded my ef hatch for it and it has a vibration when im at a stop at idle its a 91 se model all stock any insight I think it might be mounts but I could be wrong any help is appreciated.
All Accords equipped with automatic transmissions used an electronically controlled rear engine mount to reduce low frequency noise and vibration. The mount contained 2 fluid filled chambers separated by a computer controlled valve. At low engine speeds, fluid is routed through the valve damping vibration. Above 850 rpm, fluid is routed around the valve making the engine mount stiffer.
So what's your idle set at? if that's good then check and see if your electronic controller is faulty.
Actually the mount is expensive. $150 or so and it is a pain to get to.Originally posted by Carolinasfinest View Postshouldn't be too much for the part. labor is whats gonna get you. unless you do it your self.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
That's if you buy the mount brand new, and if your going do that might as well go with some solid mounts. The mount really isn't that hard to get to the hardest part is jacking the car upOriginally posted by wildBill83 View PostActually the mount is expensive. $150 or so and it is a pain to get to.
Didn't even realize this. From what I've read though, he should be able to switch to a regular mount, correct?Originally posted by BramptonCB View PostAll Accords equipped with automatic transmissions used an electronically controlled rear engine mount to reduce low frequency noise and vibration. The mount contained 2 fluid filled chambers separated by a computer controlled valve. At low engine speeds, fluid is routed through the valve damping vibration. Above 850 rpm, fluid is routed around the valve making the engine mount stiffer.
