I drive a 92 accord ex and iv checked the cel codes and I get 1 15 43. My car normally starts and runs for a minute and will just die. It doesn't run rough at all just dies and when it does the cel light oil light and battery light stay on and when I try to start it again it just cranks. Turn the key off and on a couple times and crank it will eventually start back up but then die out again. So I'm getting the ignition output signal code and I don't know what I need to check or where to start if anyone can help I'd really appreciate it. Just had my second daughter 2 days ago and I need my car.
Just for reference the head on the engine was rebuilt last year and ignition coil, wires, distributor were all replaced after my timing belt broke. What could be left? But like I said the engine runs great when running this problem just started and last time it did this I finally got it running and drove 100+ miles with no problems. Just happens on first startup so far.
Any help is greatly appreciated. Don't know if I forgot anything but I can answer questions you have.
