When I turn my a/c on and I try to take off at a red light I can push the gas pedal to the floor and car won't speed up fast...it start extremely slow barely moving.... It barely accelerates.... Any idea? Or any other info you guys may need to help me please. Thanks
A/c on and car goes snail pace
No my car doesn't speed up. Light my dim for a second when I start it but then picks up. Like I know a/c draws power but not to this extent. Thanks man for the inputOriginally posted by Raf99 View PostWhile accelerating if you turn the A/C off does the car speed up right away?
Do your lights dim?
If you are saying turning the AC on causes this symptom how do you fix the problem if turning the AC off doesn't make the problem go away?Originally posted by Truballer328 View PostNo my car doesn't speed up. Light my dim for a second when I start it but then picks up. Like I know a/c draws power but not to this extent. Thanks man for the input
This. It takes like a second for the A/C clutch to disengage. You should feel a return of power, if not, you may have other issues.Originally posted by Raf99 View PostIf you are saying turning the AC on causes this symptom how do you fix the problem if turning the AC off doesn't make the problem go away?
A tune up consists of:
Spark plugs
Cap
Rotor
Fuel Filter
Fluid top off
That's it for the most part.
Oh yea it drives fine when a/c is off. Thought u meant as I was driving and turn it off. The problem consist of initial acceleration. No acceleration problem when a/c is off. Problem acceleration when a/c is ON. Hence title.
Sonikaccord- I have done sparks, fluid top off.
I haven't done cap(distributor cap?)
Rotor?
And haven't done fuel filter....
Any ideas?
Yea a/c works pretty good, freezes me. Lol but yea, it's at initial acceleration where it doesn't want to take off. But was I'm driving it goes through and drives fine. Any ideas, what do you mean by unit? What unit exactly? CompressorOriginally posted by Raf99 View PostI did mean when you were driving and turn it off. We all know that the A/C steals HP from a vehicle due to the extra power required to operate the unit. So it sounds like your unit is faulty, sticking, etc., which is dragging things down.
Does your A/C work?
Tighten your alternator belt, or if it is good and tight check the belt itself.. My belt was worn beyond proper use - I finally replaced it due to excessive squealing practically all the time.Originally posted by Truballer328 View PostNo my car doesn't speed up. Light my dim for a second when I start it but then picks up. Like I know a/c draws power but not to this extent. Thanks man for the input
With it replaced/tightened car picked up much better, but then again mine is a 5-speed - and I removed the PS beltOriginally posted by Truballer328 View PostCbr-dee--- I get a squealing when the car is cold at the beginning, when I first turn on the a/c. Then it goes away. Very briefly.
