Any ideas on how I can make my steering a lil tighter... Steering is pretty loose. Turns to easily.
Tighter steering?
Remove the power steering pump and do a manual rack conversion.
Or an easier way is get a 88-91 Prelude steering wheel. For my conversion I had to grind a lot off of the back because it was rubbing on the back making it difficult to steer.Be unique, like every other person.
CB7 Sold________________________E34 Sold________________________E39 Current
Your question/description is unclear. If it's loose you need you need new joints and/or bushings. If it turns too mushy and you want it to be more responsive then get poly bushings. If for whatever reason the steering is too light and you wanted it stiffer, the only way to do that without degrading performance would be stickier tires or get a smaller diameter steering wheel. If you are talking about tightening up the rack for improved steering ratio, that will require custom work. Easiest way would be to shorten the tie rod radius to spindle radius. It will quicken the steering rack and increase effort.Last edited by Domesticated; 04-27-2014, 02:56 AM.'93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
Originally posted by Flip-Eye View PostHow does changing the steering wheel to one off a prelude affect steering effort?'93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
Originally posted by domesticated View PostIt probably has a smaller diameter which requires a greater force on the wheel radius to produce the same steering torque.
But that reasoning might actually work for what you are looking for, but I do not think the Prelude wheel will be small enough to make a difference.Be unique, like every other person.
A front sway bar from a 96 97 accord EX makes a small difference. I also used energy bushings on the ends of the sway bar. Just make sure its from an EX model because the other DX lx bars are the same as our cb7, I'm pretty sure. Correct me if I'm wrong. But that is exactly what I'm ridding on with front and rear strut bars, my car handles a lot better... the 88 91 prelude steering wheel could be a good idea. I'm sure it could look more appealing also.
