I have a 1991 honda accord and the s light will flash which causes my car to crank but It will not start. I have tried looking up the codes and nothing pops up I have checked the tom and the shift solenoids and they are working properly if any body has any more ideas on what it could be let me know.
sport light
what trouble codes are you getting ? also are the from the s light or check engine light ? if you can post a video it will be very help full .Originally posted by hondaman97 View PostI have a 1991 honda accord and the s light will flash which causes my car to crank but It will not start. I have tried looking up the codes and nothing pops up I have checked the tom and the shift solenoids and they are working properly if any body has any more ideas on what it could be let me know.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
That's what i was thinking . I recently had a issue where the "s" light would flash but no start . I had spark but could not figure out why no fuel but "s" light flashedOriginally posted by cloudasc View PostMy guess is a faulty main relay.
The things are needed for combustion.
Air (intake/exhaust)
Fuel (Gas)
Fire (Spark)
The main relay affects gas delivery.
. Op turn the key to the run position and listen for a click from the main relay . Make sure radio is off . then let us know if it is clicking . Also list to this man cloudasc he has saved my car many time's .
Car safety checks
Fluid Capacities
The way I know the S light can come on in regards to the Main Relay, is while mine was not plugged in, I turned the car to ACC, and the sport light was on even though the button was not pressed.
The main relay is under the driver side dash, under/behind the cruise control unit. The main relay will have PGMFI written on it, under the cruise control (CC) unit.
