I need help, I was driving and all of a sudden the engine light came on and my engine stopped, so all the instrumental's lights came on. A minute after I started it up? It started up, and it stopped on me again like a min or two later. This engine stopping thing would happen just out of no where. Also when I was doing my oil change, I smell gasoline mixed in with my oil. Please help me!!
Engine stopped on me a few times
Could be an issue with the fuel injectors, done any maintenance on them since you've had the car?
Have you noticed the car running rich?
RIP my last two CB7s.
New rides:
'82 Volvo 245 drift project
'87 Volvo 244 daily
Born2DieApparel.com
The only way I can think of where you would get gasoline mixed in with the oil is if you have both misfire (so the gasoline in the cylinder doesn't burn) and bad rings (so the gasoline blows by the rings into the crankcase).Originally posted by FizzupTK View PostAlso when I was doing my oil change, I smell gasoline mixed in with my oil. Please help me!!
Of course, if the rings are bad enough, it will cause misfire. You might want to do a compression check.
There is also a DIY on how to rebuild a dizzy, got a JY near you? Get a used dizzy to gut for parts and a dizzy oring kit and go to town.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Question
Did you clean your motor? If yes, disconnect your dizzy an wires connection an blow it out, dizzy wires always have to be dried.
What gasoline do you use? As for me... Shells in town & Chevron out of town (long drive) both cleans fuel system but one cleans better when driving distances.
When was the last time you cleaned your egr? If never, remember that our cb7s are almost our age. Lol
Do you know how to pull the codes from your cb7? If no, search it an you'll find a post.
, sucks how Honda sells the distributor for a crazy price, had to get an aftermarket on it.
