92 prelude auto to 5 speed swap
    I have replace the motor and trans at the same time. I have a H23 and 5 speed trans. I have everything back in the car and all the wiring back in place. The motor will turn over but will not start. I left the automatic instrument cluster in the car. On the cluster when trying to start car park is lite up and D4 is lite up. I have changed the wiring to compensate the 5 speed. I'm lost at this point.
    start with diagnosing: check to make sure you have spark and fuel; make sure everything is connected; check to see if you have any CEL codes.
    90 LX (R.I.P.) http://www.cb7tuner.com/vbb/showthread.php?t=137301
    91 EX (DD) http://www.cb7tuner.com/vbb/showthread.php?t=142483
      did you take out the tcu? lol
        like frohawker said start with diagnosing the spark and fuel. Did you happen to swap the neutral safety switch? maybe that is causing it not to start
