Hello I just have a question about the transmissions in the cb7s. When I'm cruising in my car then I let off the gas then try to reaccelerate its almost like my transmission plays catch up like the rpms have to go up to where they were then it like catches almost like a hesitation in the transmission maybe? The problem never happens at all from take offs this only happens when I take my foot off the gas for a few seconds then reaccelerate I know my car has 208k miles on it but is this normal for these cars? Please note that somebody I know with a 1993 HONDA ACCORD EX has the same thing but its not nearly as bad as mine on the 93 its just slight and the car has 190k. Thank you in advanced to anyone who helps.
1990 Honda Accord Ex Automatic Transmission
At what speed does this happen? When you let off the throttle, the transmission may shift up (if not already in 4th) and rpm will drop or the torque converter may lock up (rpm will drop about 300). When you push the accelerator again, the transmission may then shift down (or the torque converter unlock) causing the rpm to increase until you get to a steady throttle position again. Along with checking codes (if any), is the fluid level good? Has the fluid been changed at all?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
The fluid was recently changed a few weeks ago as preventive maintenance as I've put 31k on the car since I owned it and used oem fluids. I think I notice it more so around 40-50 mph maybe when i'm slowing down around a intersection then I re accelerate and it does it I mean the rpms don't go high but i'll have to check it again later today to see if when this happens it's shifting up also the fluid level is right at the full line. Would it help any to adjust the transmission cable? I will have to see if it does it later today though I haven't been noticing it it shifts fine when going from take off and sometimes it has a hard downshift but as do many other automatic cb7s I've been in.
