Hello I have a 1990 HONDA ACCORD EX trying to figure out why my ac isn't working fuses look good both fans do not come on though when ac is turned on and nether does the condenser but I heard there's a way to jump the condenser to test it to see if it turns on how do I do that exactly? Any help is greatly appreciated thank you in advanced.
Ac Not Working
Was it working recently and now doesn't? Or is it something that hasn't worked in a long time?
There is a pressure switch mounted to the AC line behind the driver side headlight. If the pressure in the system is low because of lack of refridgerant, the compressor will not engage. To check if the compressor will run, remover the electrical connector from the pressure switch, then with the engine running, turn on the AC in the car, then jump the connector briefly. If the compressor clutch is working correctly, it should engage; I think the condenser fan should also come on. If these things work, then it is likely low on refridgerant. Do you know if the car has been converted to R134?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
