I got a 92 sedan F22A1 that still over heats after a week of fixing. Had head gasket replaced and heads resurfaced, new radiator, water pump, thermostat, radiator cap, hoses, plugs and wires, timing belt. Worked well for a week then started to overheat again until I blew the head gasket again. Is there anything else I might have missed? Stressed
Overheating Problems
Are your fans coming on like they're supposed to?
Were you not watching your needle like a hawk the second time around?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Is your tstat installed backwards? Do you have any leaks? You might have a bad head gasket and that is the primary problem. Did you do the work? If you had a shop do it I would be taking it back.
Really sounds like a headgasket problem to me. Exhaust gasses getting in the coolant will overheat your motor in a hurry.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
